Thread: initiation
Old 01-28-2014, 11:44 AM   #12
BYprodriver
BYprodriver's Avatar
I'd be willing to bet that the bolts on one of the half-axles sheared off at the trans or broke at the joint
Good news? The engine is still running and new axles wont break the bank.
+1 on this. Should be able to push the car a few feet & hear the axle jumping around to verify. If the bolts came loose get new bolts (make sure you get the right length)
clean everything very well & use blue loctite on the bolt threads then torque to spec.
