If the engine had stored fuel trim from a failing component before, a handover is required to clear it up, because the car doesn't know the engine has been repaired.
To adapt the throttle turn the key on for 1 minute, off for one minute and do that a couple of times, then fire it up and turn on every consumer you can, A/C, rear defogger, all the lights and etc and let it idle.
Check for vacuum leaks and watch the fuel trim.
US Patent 8,992,089 &
US Patent 9,416,697
