Old 02-21-2006, 04:30 PM   #14
PorscheDoc
That sounds like a cable is way out of adjustment. Both the stock shifter and the B&M should be tight side to side. If you want the cheap fix, i would pull apart your console and try adjusting the cables and test it out (you can make the adjustments with the shifter in place until if feels good, then put the console back together)
Karl Wilen
RennsportKC
PorscheDoc is offline   Reply With Quote
