			It's alive!!!! bu wa! ha! ha! ha! ha!!!!,  Got the engine re-installed and cranked it up.  Cranked and idled smoothly at first, then the idle fell off and got thready, a little gas to keep it going and then 3 bangs and I shut it down quick.  I was sure that was curtains and the CEL came on.  It threw an O2 sensor low voltage, a "random misfire" and misfires from both sides of the engine. Nothing ventured, nothing gained, I fired it back up.  Much less drama this time.  It was still searching for idle, and all the oily hand prints were buring off the engine.  So I shut it down and cleared the codes.  It fired right back up again and I let it get warm at idle, took it to 2000 rpm (very smooth) then back to idle for a bit, 2500 rpm then idle for a bit, 3000 rpm, then idle all smooth.  Idle was much improved but not perfect.  Gauges seemed proper, no warning lights and no more CEL.  BUT, when I put it in gear, and let the clutch out, it made a noise like clashing gear teeth.  My thought was it sounded like the flywheel just touching the starter gear.  It did that twice and then quit.  Ideas?
				__________________2003 S manual
