Old 01-22-2014, 06:15 PM   #11
Shehadehd
Shehadehd's Avatar
So I've made my choice on two distributors for plexiglass and lexan and I'm getting some samples sent for cutting.
I've also located three sources for rubber sealing and I'll be testing each for heat resistance, sound deadening, aesthetics, and to make sure no fumes leak through.
The mounting method I'm using now requires you to swap out the OEM clip nuts for a different set that the bolts lock into better. I'm currently looking for a set of bolts that let me keep the original clip nuts without loosening on bumpy roads.
It will be at least a week until I get the samples I ordered and possibly a week more before I'm satisfied with the dimensions, seals, and hardware. I'll keep you all updated and probably get a formal count on who is interested so I can send out a batch order of plexiglass or lexan.
Shehadehd is offline   Reply With Quote
