Thread: o2 sensors
Old 01-22-2014, 07:25 AM   #6
Burg Boxster
More than one sensor going at a time is highly unlikely (unless getting fouled by something upstream).
The fault codes associated w/ O2 sensors don't mean sensor is bad but rather the value being reported by them is outside of spec. Sure it could me sensor itself is bad but more than likely it means there is another problem up stream... and doubly so when more than one goes at a time.
What codes are you getting? And more importantly, what work was recently done?
With a multi-meter you can easily test each sensor to see if it's truly dead.
Good luck
