Old 01-22-2014, 04:41 AM   #12
billj18
billj18's Avatar
My wheels are not nearly as big, but I had a similar problem when I put 15mm spacers on my 17" Sport Classics. It seems that the hub, spacer, and wheel mounting surfaces must be scrupulously clean. The smallest bit of dirt or rust keeps everything from bolting down tight and parallel, causing vibration. I had to wire brush the hub surface and the back of my wheels to clean everything up. Of course, mine is my daily driver, so it's exposed to the elements. YMMV.
Tip: be sure to put a thin coat of anti-seize between the aluminum spacer and the steel hub, or else they will weld themselves together.
Bill
BJ's BlackBox -- 2001 Boxster
1997 SAAB 900S Turbo
1980 Maxda RX-7
1974 Fiat 124 Spider
1976 Datsun 260Z
billj18 is offline   Reply With Quote
