Old 01-21-2014, 04:38 AM   #54
Benjamin
Benjamin's Avatar
Originally Posted by Benjamin View Post
7 or 9 for the headlight switch (7 if you want to leave the 2 green, 9 if you want to change all)
I take that back. I tore into my headlight switch this morning and found that (at least on mine) they are 3mm LEDs, and not the PLCC2 SMD type.
And here is a picture of the inside of a climate control. I have a water damaged one on my parts shelf that I used to replace my LCD. I removed two LEDs on the lower right when I was practicing my removal technique.
2000 986 S - "The Black Widow"
Benjamin is offline   Reply With Quote
