Old 01-20-2014, 05:23 AM   #1
Mark_T
Meticulous surface preparation is everything. You can obviously do a better job if you remove the calipers from the car. A few cans of brake cleaner, a wire brush, and lots of rags should do the trick. Plug the holes with rubber stoppers and tape off the seals.
I used VHT caliper paint and it seems to be holding up well.
'99 black 986
