Originally Posted by rfuerst911sc
Yes I did but in that situation there is a lot of on/off throttle vs cruising that's why I asked. I will probably be purchasing from you but I have to actually get my car first !  Obviously you are doing this mod with the muffler removed from the car. Are there any potential fitment/clearance issues when doing this mod outside of the car ? Do you recommend tack the two tubes in place then loosely install the muffler to make sure everything is straight with no clearance issues ?
The first set I made had fitment problem so I changed the design a little. WHen you install them just make sure you tuck then as close to the muffler as possible. Taking the muffler off is only a five minute job. Getting the bumper off is probably harder. You dont need to tack the parts in place. Just mark where the holes go. Then you will need trim the the pipes to fit. You will end up taking about an inch off each end.
