Old 01-18-2014, 12:59 PM   #10
seningen
seningen's Avatar
Originally Posted by jsceash View Post
That is a problem it should only go into one side. You should have to rotate the engine one hole revolution and pin the second time before it goes into the second side. At that point it will not seat in the first side
You have your answer.
Before going to far check leak down as you spin it around just to make sure you didn't hit and valves. Quick test and save you some work in case you did.
It won't be in proper time but there should be a point where each cyl is fully closed.
If all is good, then retine properly
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
