Old 01-18-2014, 05:30 AM   #1
RedTele58
RedTele58's Avatar
Originally Posted by silverboxter View Post
what is the socket needed to remove the seat? it looks like a reverse Torx. i'm not sure what it's called.
I'm in the middle of swapping my seats out in my 2000 Boxster for GT3 sport seats. Here's the removal process:
You can use a regular 1/4", 6-point deep 10 mm socket. I used it w/ a 4" extension. (If you want to get fancy, an E12 reverse torx is the socket you asked about, but the deep 6-point 10mm fits perfect)
Drop the top when you start - much easier to work and lift seats out.
Then - follow instructions on this link - easy breezy...
Rennlist Member Gallery :: DIY GT3 Seats Install
Good luck!
Rick
