Old 01-17-2014, 02:40 PM   #1
backtopoolschool
2000-2002 Boxster S Unichip Programmer
$300 to include shipping anywhere in the continental US.
I pulled the Unichip re-programmer from my 02 Boxster S before I sold it.It is complete in it's original box with instructions. It was tuned by Unichip for a Catback, and a cold air intake. It takes about 15 minutes to install. You feel a very noticeable improvement over stock. If your in the Houston Area, I will even help you install it. Everything is plug and play. Doesn't require any wire cutting, or any permanent change to your car.
From the Unichip website
Unichip - 2002 Porsche Boxster S (3.2) tuning chip | car tuning
Adds up to 14hp & 12ft-lb with NO Bolt-on modifications (add a panel filter for even more gains).
Easily plugs into the stock ECU & ECU harness in minutes , no programming necessary .
Realizes the full potential of Aftermarket add-on's like Cold-Air-Intakes & exhaust systems , as each kit comes pre-mapped for the exact set-up of each car .
No end-user tuning necessary , just plug the kit into the car & you're ready to go.
Easily upgradeable for future add-on's.
Each kit comes with two maps : a low octane performance map & a high octane performance map, switchable from within the vehicle.
Fully tuneable by a Unichip Custom Tuner for customized add-on's . This basically means that the Engine Management System in your ride is now as tuner friendly as the most advanced Standalone systems in the world , without sacrificing any of the factory features. This feature is unmatched by any reflash-tuning or other similar product.
Plug 'n Play harnesses are fully Flux capable - purchase Flux when you purchase the Plug 'n Play kit or upgrade later - Flux simply plugs into the Unichip Plug 'n Play harness.
Plug 'n Play kits are removed from the vehicle in minutes , returning the vehicle to stock tuning , without leaving a footprint of ever having been modified (a feature which reflash-tuning cannot match).
backtopoolschool is offline   Reply With Quote
