Old 01-17-2014, 01:06 PM   #167
Walter White
Originally Posted by Walter White View Post
I was just figuring out the minimum and maximum pressure the IM shaft would see if it were sealed with a freeze plug. Using P1/T1 = P2/T2, volume is not a variable. So that would mean that if the bearing is sealed with its own seals, it would see the same changes in pressure over temperature? Venting the shaft would not help? The grease in the sealed bearing will still see the same pressure changes I think.
I have been spin-testing my bearing with the supplemental seal and it spits out a little grease each time I start spinning it after a cool down period. I have a feeling my prediction may be correct. It may be that using grease will require some type of ventilation.
It's all bad
Walter White is offline   Reply With Quote
