Old 01-17-2014, 12:32 PM   #3
alanqning
Instructions are to use Jumper Cables. I used Jumper Cables at it worked.
Put the key in and turn to unlock, that should turn off the alarm.
Originally Posted by Xcellr8 View Post
Thanks for the helpful tips. Tried again leaving the key in the door. No difference.
Using thin wire with alligator clips to carry power from donor battery. Will that work, or do I need jumper cables?
Meanwhile, I've removed the fender splash shield/liner and looked up at the area near the back of the headlight, felt around the sheet metal next to that and am not seeing or feeling the pull ring.
Came back home to read the postings again to see if I missed something about the cable. Wondered if it had been pulled once before, would the ring come off?
Also now wondering if the cable has already been re-routed. I'll go back out to check the tow hook area when it warms up a little. Today is 15 degrees with wind, making it close to zero.
Black on Black 2001 Boxster Base
Clutch Masters Stage III Clutch
Luk Flywheel // IMS Retrofit // Rear Main Seal
alanqning is offline   Reply With Quote
