Old 02-19-2006, 06:39 PM   #1
MNBoxster
Hi,
Here's the 60k mi. Service. Check it for yourself and see if it's something you can do. The majority of it consists of visual inspections of various parts and systems. You don't necessarily need to be Porsche Trained to spot a problem in most of these areas, anyone with a greater than passing knowledge of General Automotive wouldn't have a problem, except for Fault and Code checking, which you can do with an aftermarket reader. But by following a checklist, you will likely check areas which you otherwise would not...
Happy Motoring!... Jim'99
