Old 01-15-2014, 02:35 PM   #11
healthservices
Registered Boxster abuser
healthservices's Avatar
When the engine is at top dead center TDC, & the cams are properly allocated, all cam followers are on the base circle of the cams. All valves are seated.
This is why if the engine will not be started for a month or more you should put engine at TDC to unload valve springs.
I can understand that for number one... but what about cylinder 4 when 1 is at TDC?
lets say the Firing Order is 1-6-2-4-3-5 would it not stand to reason that the number 4 is at btdc and sucking in air with full lift? maybe I'm just reading too much into it.
