Old 01-15-2014, 10:27 AM   #11
BYprodriver
BYprodriver's Avatar
When the engine is at top dead center TDC, & the cams are properly allocated, all cam followers are on the base circle of the cams. All valves are seated.
This is why if the engine will not be started for a month or more you should put engine at TDC to unload valve springs.
