Old 01-15-2014, 07:51 AM   #10
healthservices
Registered Boxster abuser
healthservices's Avatar
Originally Posted by Jamesp View Post
The timing procedure seems to go like this - Lock the engine at TDC and set the valve timing using the timing tool. Head 4-6 is shown first in the repair manual, but I dont see a difference in which head gets timed first as there is only one TDC sr=etting on the crank. Now for the part I missed - Roll the crank 360 degrees (that's half a rev of the cams) and see the other side. Now the cams are set 180 degrees out from one another. I have one set of cams out 180 degrees. BYprodriver hit it on the head.
I really wonder if the motor is a interference motor when the instructions tell you to just rotate the motor 360 with no regard to cam position?
