Old 01-14-2014, 04:26 PM   #11
BYprodriver
BYprodriver's Avatar
Originally Posted by Jamesp View Post
The question I have is do you bend the valves 180 out of time? Surely this has been done before.
NO, I'm thinking you just forgot to spin the engine 360 degrees after setting cam timing on 1-3 cyl bank, & prior to setting 4-6cyl bank. If that's what happened the valve to piston clearance is as designed but DME is not programmed to send spark & fuel at the appropriate time for 4-6cyl combustion stroke.
