Old 01-14-2014, 03:31 PM   #11
Jamesp
Beginner
Jamesp's Avatar
Originally Posted by healthservices View Post
Not that you did it wrong but if I remember correctly the timing tool for one head is not used for the other when the motor is at TDC for number one.
Am I correct?
The timing procedure seems to go like this - Lock the engine at TDC and set the valve timing using the timing tool. Head 4-6 is shown first in the repair manual, but I dont see a difference in which head gets timed first as there is only one TDC sr=etting on the crank. Now for the part I missed - Roll the crank 360 degrees (that's half a rev of the cams) and see the other side. Now the cams are set 180 degrees out from one another. I have one set of cams out 180 degrees. BYprodriver hit it on the head.
2003 S manual
