Great info,I have not had that problem with my 06 Boxster s but my winter beater a toyota Echo did,couldent get fuel in tank,ended up bypassing the charcoal cannister and voila works again,but gasoline fumes will come into the garage now if its left inside.I was told that this problem with fuel not filling and destroying the cannister or parts leading to it is trying to over fuel the tank,fuel will drain back down the overflow into the cannister and destroy it as its only ment for fuel vapours,so when the pump clicks full,pull it out,dont try and squeeze that last few dollars in.
