Old 01-14-2014, 06:48 AM   #11
seningen
seningen's Avatar
[QUOTE=Jamesp;380902]
That engine has compression all over the place.. I can hear it based on the load on the starter.
I had the engine completely torn down for an IMS shaft replacement.
I locked the engine at TDC and timed both banks using a factory built timing tool and the instructions from the 987 manual
It has the original lifters in it.
Both banks were timed the same way, meaning engine locked at TDC and timing tool used.
The picture below shows bank 1-3 timing
Still worth a quick double check that your still in time.
pull the oil scavenge covers and make sure the cam sprockets didn't slip.
left and right bank do get timed 180 out of phase. Been a while since
I personally checked but the cam holder gets rotated such that
when timed both camshaft sides are slightly on the outside of the case.
Double check that as it's been a couple years since I did it myself.
mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
