Originally Posted by Jamesp
On to more pressing matters, any idea why a motor with fuel and spark won't run? What would you run down first? I'm draining thee old fuel, it did hit a few times but wouldn't catch.
Ok - I'm done hijacking this thread.
I thought I was hijacking this thread!
Maybe try disconnecting the battery for a few minutes to reset the ECU?
If I were to go with oil lubrication on the IMSB, I think I would try to pick up the oil right after the oil cooler outlet. There it is filtered and cooled. If I go with injected oil, I am going to take the cooler off and see if I can drill and tap a fitting into the oil passage that exits the cooler into the engine case casting.
