Originally Posted by lewbo
Can someone give me some guidance with induction systems, which is the best looked at true flow and EVO, baring in mind that I live in a hot climate - not sure if a cone type induction kit is the right choice, although the EVO sytem does have a enclosed fresh air box. Also worried it might mess up the MAF sensor. (2001 'S')
At this point I would have to say the best one is the OEM one. What are you trying to achieve by changing out oem system? You should weigh the pros and cons.
EVO Induction Pros
1. More induction sound.
2. Ummmm......
EVO Induction Cons
1. Little or no Hp gain.
2. Possible MAF foulups and CEL's
3. Possibly void warranty
4. Total pain in the ass to install.
You can achieve your goal of more induction sound by desnorkling plus as you mentioned the EVO cone induction isn't a 100% cold air induction system like the OEM system. In that respect, you are taking a step back by switching to the EVO. The EVO has a "heat shield" which may help some, but I really doubt it is a completely sealed system like the OEM induction.
