Old 01-12-2014, 09:59 AM   #15
Jamesp
Beginner
Jamesp's Avatar
So the oil pump is driven by the IMS shaft. How about a small oil passage through the hex key from the oil pump to the interier of the IMS shaft and an open bearing at the other end? Plenty of oil, and might be an easy mod. plus your stealing oil from the best place possible.
A small hole in the oil pump driven gear connecting with a passage through the center of the hex drive key, and another small hole through the IMS end fitting at the bottom of the hex drive hole would do the trick.
Couple that with a creamic bearing for overkill. Voila!
2003 S manual
