Old 01-11-2014, 08:20 PM   #1
dghii
Boxster Seat Disassembly Procedure Part 1 of 2
986 Boxster Seat Disassembly Procedure
Seats are expensive to ship so I thought I'd pass along how to disassemble a seat to ship cushions without the seat rail to save a few bucks. Hope this helps somebody.
1. Gently pry the seat height adjustment lever located on the outboard side of the seat cushion, Pry on the rearward part of the lever. Do not have remove the lever that adjusts seat back position.
2. Place seat on it's back to access the underside of the seat cushion.
3. Remove Phillips head screw located toward the back of the seat cushion.
4. There are two electrical connectors to disconnect. The first connector is the white two conductor cable beside the large connector.
5. The second is a smaller colored connector contained in the large rectangular connector. My smaller connector was green. To remove the green connector, slide the black clip on the side of the large connector rearward. The green connector will slide out of the large connector.
6. With connectors removed, unclip them from the seat bottom. There may be a couple of wire ties to remove as well.
7. Unclip white plastic clips from front of seat cushion.
