Originally Posted by bob567
I undo the latch the windows drop down the parking light is on but the open top dash light does not come on so therefore the top will not respond to the switch.
Any help much appreciated.
The latch microswitch is working because the windows drop when the latch is open.
The hand brake microswitch is working because the PARK light is on.
The top's dash light will not come on until you press the button to the open position.
If you press the top's main switch and nothing happens you may have a bad main switch.
There's a second micrositch within the latch aside from the window's microswitch.
Press in and out with your finger to make sure it's not lodged in. also try pulling out a bit if it's stuck in.
Happy Boxstering,
Pedro
