Old 01-09-2014, 04:26 PM   #10
talvez
Originally Posted by Steve Tinker View Post
The crank pulley is just that - a pulley bolted directly onto the crankshaft, so IF you've pinned down the noise correctly, its the crank main bearings or end float thats making the noise.
Id like to know more about what the causes of a noisy crank pulley can be. Is there any other ways the pulley would be making noises? Im also having noise come from the crank pulley.
A floating crank end or bad main bearings is not what I need right now.... Would a bad end float cause a leak to form behind the pulley?
thanks you guys
talvez is offline   Reply With Quote
