Old 01-09-2014, 03:26 PM   #1
amagalla
amagalla's Avatar
Someone should mention that these are 4ohm speakers, and the stock 5.25" speakers are 2ohm. You get half the power/effective volume output per a given volume setting. A custom amp setup or individual channel adjustments could fix this, but beware if you are using the stock cdr220.
I suspect that the original setup either used a 2 ohm stable amp or that the bass reflects in the doors were wired in series (to make 4 ohms) and the amp was bridged to send one signal to the door speakers. Does anyone know for sure?
Tony
