Old 01-09-2014, 08:03 AM   #11
The Radium King
The Radium King's Avatar
that's what I have - 987 airbox, maf housing from my 986 airbox, cayman tb (same as 996 or 997) and 997 plenum (I didn't see the need to pay the extra $ for the pedro unit). I am very happy with the result.
there is a thread here on how to modify the airbox to work - there is a 'muffler' on the outlet that needs to be dremmeled off, and an opening (where the outlet pipe opened into the muffler) that needs to be plugged - I used a waste piece of the muffler plastic and a $20 plastic welding kit off ebay to get it done.
to use the 986 maf housing, just saw it off your old airbox (smooth the edge) and fasten it to the 987 airbox.
you'll need a variety of silicone elbows and reducers, etc. for example, the 997 tb, while 3" (76mm) on the inside, is 3.25" (83mm) on the outside (thick metal lip). the maf housing, however, is approximately 3" ID and OD (thin plastic). so, you'll need to reduce to mate the two.
further, you'll have to make a hard 90 degree turn coming off the tb, as the 997 plenum (or pedro unit, as he just modifies a 997 plenum) doesn't angle like your oem plenum. i accomplished both by using a silicone 90 degree reducing elbow that goes from 3" to 3.25".
to attach the maf housing to the airbox you have a number of options. the airbox outlet has a flange on the end - you can saw this off and use a 3.25" to 3" silicone straight reducer to join the two (pls confirm the 3.25" dimension, as I didn't do it this way). or, I found that the 3.25" end of the reducer will press fit inside the flange, which is what I did (I inserted a 3.25" ring sawn off an old aluminum coupler inside the reducer to keep it from collapsing).
to join the whole assembly together I used a piece of the original ducting; inserted in the elbow at the tb end, and connected to the maf housing with a 3" silicone coupler at the other end. wrap in metal foil tape and done.
notes:
- airbox install is a ********************; I had to remove driver side intake manifold and bend up engine cover mounting tab to get it in.
- mounting points are the same for both airboxes, however, one point is a bolt on the 986 and a stud on the 987; I sawed the head of the 986 bolt, slotted it and made a stud out of it.
- you might have to jimmy your fuel tank vent line a bit.
- you can make fitting the elbow off the tb a little easier by sawing off the little flange on the engine compartment.
- may wish to incorporate an 'airflow smoother' to keep the maf readings stable - this is a honeycomb or mesh that sits in the airflow upstream of the maf. I got one off an old bmw maf pipe and fastened it to the end of the maf housing I had fabricated. does it do any good? no idea.
Last edited by The Radium King; 01-09-2014 at 08:04 AM. Reason: beat to the punch by shehadehd!
