Old 01-09-2014, 07:38 AM   #11
Yellow986S
Yellow986S
Yellow986S's Avatar
still going ...
if you want to go the ipd/gt3 route and increase your maf housing diameter, the cayman/987 is a match. further, the cayman/987 airbox is a HUGE improvement over the one that came with your 986. so, put in a 987 airbox and maf housing (the 986 and cayman/987 use the same maf) and you are now 83mm throughout. as already posted, this will f-up your cars tune, as the ecu uses the area of the maf housing to calculate airflow. this means:
1) hope the computer can adapt (if you search on this forum there is at least one person who has done such on track cars and had no issues);
2) expensive custom tune (Pedro is probably your best and least expensive option here); or
3) try to use an ecu map for a 996 3.4 e-throttle pre-variocam+. this map is designed for the larger maf housing diameter and *should* work on your car. cost would be the amount of time it takes your mechanic to push it with a piwis or pst2 (3 minutes). I eventually want to test this out but would love someone else to prove the concept ...
Is the 987 airbox a direct bolt on that I can swap? if not what needs to be done to make it work.
I understand now that the GT3 TB is too large and will do more harm than good unless I change the MAF, which I don't plan to do.
Can I use the 76mm 997 TB, 987 airbox, and Techno Torque plenum?
Will this affect the MAF and will I see any performance gains with this setup?
Yellow986S is offline   Reply With Quote
