To the best of my knowledge, no one has recommended using a TB any larger than a 76mm or 78mm with at the M96 engine. Also, keep in mind, ideally the ECU should be remapped in order to adapt to the significant increase in air/fuel ratios. You should check out Pedro's kit for the 986.
