Old 01-06-2014, 04:02 PM   #15
Jamesp
Beginner
Jamesp's Avatar
One other, other comment. Using a semi soft plastic scraper does a great job of removing the original sealant, and any Loktite 5200 from the flange area without scratching the aluminum sealing area. The 99 cent scraper gets trashed instead. Then clean everything up with a lint free rag and solvent that does not leave any trace of oil or itself. I use carb cleaner, followed up with brake cleaner followed up with acetone because I am OCD about leaks. The acetone alone should do the trick, but if it is all there on the shelf... Also if the flange area is not completely clean and dry when you apply new sealant, the sealant will never bond with the metal and you will have a leak.
2003 S manual
