got all the stuff, got home. Jacked it up, everything was good. Went to inspect oil filter first. At 87k, it looks great. I noticed a metal particles, but it was what you would expect out of any vehicle with age. Not really of any "size", almost like a peice of glitter.
Went to undo the oil drain plug, and it popped right away. The head of the hex broke off, with the rest of bolt in the pan FLUSH. Went and got an extractor, with a drain plug the same size. They were out of the OEM porsche plug, got the typical 15mm one with same threads and size.
Extracted it, however the bolt instead of leaving from the bottom, went INSIDE the pan
When I used the drill bit, im assuming it went all the way through the bolt and pushed it in.
So, what to do now? Back hurts from the 6" clearance from garage floor. Wifes not too happy... Im assuming drop the 13 bolt oil pan and just grab it out the bottom. Reseal with rtf or the locktight stuff and im back in business within an hour?
