Originally Posted by tconnarn
Thank you for the feedback, i may try to test the voltage on the wires next. i replaced the starter today and it started up, but only intermittently. On the diagnostic software, the Clutch Switch is not actuated when i press the pedal down, but the "Cruise Control Readiness" switch does respond on "On & Off" on the diagnostic software. What do you think? Im thinking about replacing that next and see what happens... Thanks for the help!
Tex
Problem Solved - Replacing the 2 Clutch Switches took me about 15 minutes. She starts right up every time now. Thanks for the help. Now its on to the next project...
