Old 01-02-2014, 08:01 AM   #21
Jamesp
Beginner
Jamesp's Avatar
Originally Posted by Brad Roberts View Post
Yes! It would have worked, but I doubt it would have reached to the starter.
Do you have the blue single wire plugged into the bottom of the Alt.?
Did you go back together with the 987C large AOS? People tend to call it the "Motorsports" AOS but Porsche Motorsports has nothing to do with it
It reaches the starter easily. The alternator has a plug (not sure of the wire color, but it is plugged in, the high amp wire, and the red wire.
I replaced the AOS with the same as it had. Is there any other way for oil to get into the manifold? There was so much oil on top of the engine that it created an oil slick behind the car as it sloshed off. It appeared to be coming mainly from the butterfly valve in the forward manifold tube.
