Old 01-01-2014, 09:02 AM   #3
Brad Roberts
Brad Roberts's Avatar
Two pole works fine
The alternator chargeback wire: take it to the battery side of the cutoff switch (this happens to be the starter wire also)
Does it leave the big black heavy wire "hot" running through the car AFTER you cut the switch? Yes, but all else is cut.
Super simple to wire it this way, I use the Cup car style electric cut. ZERO failures in 10 years of use. Easy to wire a switch for the driver and button for the outside of the car.
The "twist" style cutoff SUCKS to run two cables. One for driver and external pull
B
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
Brad Roberts is offline   Reply With Quote
