Old 12-29-2013, 11:08 AM   #14
drbodzin
San Diego Boxster
drbodzin's Avatar
Finished getting the AEM Gauges installed.
Here I installed the wood veneer from a kit I had. This is the piece that would normally be used to
surround the cassette or CD holder.
In this pic, I cut two pieces of wood to fill in the center section. I used a dremel to grind the extra off.
Here's a couple of shots with the completed install. Chose the silver bezels to match the main gauges.
You can see how the Apexi AFC slides out and into the pocket I built.
Here's the install of the Boost Gauge sensor. I will install the Wide Band O2 sensor once I install the
200 Cell Fabspeed Cats next week.
The Boost Gauge sensor then attaches to the vacuum line upstream of the throttle body.
Happy Boxstering!
Miles
1998 Black Boxster (owned since 2001)
drbodzin is offline   Reply With Quote
