Old 12-27-2013, 03:14 AM   #3
Nine8Six
Nine8Six's Avatar
If your car is running, then the shifter-cable is disconnected from the tip. That cable-end security clip is known for breaking when you are 100km away from civilization. Look up the tip from the driver side (just behind the rear tire). You should see your stuff hanging off there :/
Easy to put back in place (temporarily)
Hope this helps a bit
