Old 12-26-2013, 06:15 PM   #1
JFP in PA
Oh, and will a failing AOS also cause a vacuum leak?
A failing AOS diverts vacuum to where it should not be; try pulling the oil fill cap while at an idle, if it comes off very hard (or not at all) the AOS is toast. We made a test fixture from a brand new oil cap and a vacuum gage that reads 0-20 inches of water; a good AOS should read about 5 inches of water, any higher than that and it needs to be replaced.
