Old 12-24-2013, 01:36 PM   #6
LAP1DOUG
LAP1DOUG's Avatar
For what you want to do, here is the easy way:
1- Place a long straight edge up and down touching the outside of each tire and extending up into the wheel well. Go buy a long rod or small aluminum shape at Home Depot if needed.
2- Measure the distance from the inside of the straight edge to your wheel lip.
3- Try a spacer matching the measurement in step 2. You can probably get away with more than this if wanted as the wheel travel on a stock vehicle will rarely get to the maximum tire overall width, and the supension will gain camber in bump.
Good luck.
Kippis
986S
991S
Van Diemen RF97
LAP1DOUG is offline   Reply With Quote
