Old 12-24-2013, 12:31 PM   #1
Yellow986S
Yellow986S
Yellow986S's Avatar
Originally Posted by jacabean View Post
This is the correct method to install . you will still have to push the arm down manually after loosening the bolts. no worries because you will need an alignment after the install is complete . the rear is a little more difficult .
I will need an alignment and corner balance.
After how long should I go get the alignment?
The new suspension must settle before I get it aligned?
Yellow986S is offline   Reply With Quote
