Just an update I found the problem the bulb was blown on the dash so the hand brake switch wires I put a bit of wire across so the light was on and i pulled the top catch down and pressed on the 2 contacts on the back pressed the button and the roof is working so I removed the part and re soldered the broken joint and that's the roof working as it should do.
Thanks for your help
