Old 12-22-2013, 07:29 PM   #1
Yellow986S
Yellow986S
Yellow986S's Avatar
Putting in Coilovers need help!
I have already removed the sway bar drop link and the 3 nuts holding the top mount of the shock.
Are there any other bolts or nuts I need to loosen to be able to push down on the wishbone and hub so I can slide the shock out?
Pelican says that you should remove this bolt but I would rather not if I don't have to.
Yellow986S is offline   Reply With Quote
