On the non-aero 3rd light, theres a connector that terminates at the light fixture, with a single connector that holds two wires. once you remove the non-aero brake light, just run two wires from the connector to the new brake light on the aero kit.
I guess to do it properly, you should take the old wire connector and reroute it into the trunk through the main wiring loom area, and then up along the underside of the trunk lid somehow.
