I got an oil seal that looks like it might fit into the end of the single row bearing IM shaft, as shown in my previous post.
It is a Beck-Arnley 052-3380. Can get these off eBay.
It is listed as 32 x 47 x 6 mm.
The outside diameter is about 2.865', where the bearing OD is 2.850", so it looks like it would be a nice snug fit into the shaft.
It is about .235" thick, but the edges are beveled so .200" is the required depth that will give maximum bite into the end of the IM shaft. I hope the distance from the bearing retaining snap ring to the end of the shaft is greater that .200". I know the end of the shaft is beveled so a little is lost on that bevel.
It is listed for a shaft diameter of 32 mm.
These seals are listed mostly as camshaft and tranny input shaft seals.
Some other seals that have a 47mm OD...
30 x 47 x 17 052-4002
32 x 47 x 10 052-3139
32 x 47 x 10 052-4005
32 x 47 x 8 052-3379
33 x 47 x 7 052-3288
35 x 47 x 7 052-3192
35 x 47 x 7 052-4000
It's all bad
