Old 12-13-2013, 07:36 AM   #2
Shehadehd
Shehadehd's Avatar
Very low voltage, 0.00 to 0.02 volts while the air pump is running. After the pump shuts off the voltage will jump up and alternate from .1 to .75 volts.
This is what I get. I wasn't able to capture the full start-up cycle because I was fiddling with the gauge to read the o2 sensor, but I got the last couple seconds while the pump was on. The Y axis is in volts.
If you are interested in a Comfort-Top module, please visit:
https://www.enhancedautomods.com/shop/comfort-top
Shehadehd is offline   Reply With Quote
