Old 12-12-2013, 08:02 PM   #14
Brian0icu812
Originally Posted by 3.2S View Post
I need a convertible top right transmission. How 'bout a $100.00 if it's a late model (for my 2001) and you could inspect the plastic gear inside. Easy to inspect, unscrew the screws on it, lift off the metal cover and take a peek. Plus shipping of course. Let me know.
Here are the pictures of the transmission. Its a metal gear inside, not sure if its the one youre needing but if its not i'll refund the money minus my shipping if your not sure as well. I took pics without the black cover, the gears are full of grease and i made the mistake of trying to wipe some away and it spreads like wild fire indoors. No shavings and the close ups show perfect gears so i assume its like new unless you nee me to look anywhere else. The top work the whole time i had the car flawless. Anyways here's the pictures, lmk if you need as i can send out monday vis 3 day priority for $8.00. Also to not get confused do you need the driver side or pass? right is in the eye of the beholder
Brian0icu812 is offline   Reply With Quote
