reply
Well I removed the wheel and plastic lining inside the well to get a look-see. As I suspected, the L shaped fill tube connects direct to the reservoir bottle there. The connection seemed loose, and was the reason for the leakage. I notice that the fill tube snaps in place with a pair of clips, however it wasn't snug enough to form a seal I guess. I played with the fill tube and found a spot where the leaks stopped, and applied a small spot of silicone adhesive to atop the clip to hopefully keep it in place. Refilled, drove it around, squirted the windshield, and thus far no leaks. Thanks all
